RCU Forums - View Single Post - TBM Props?
Thread: TBM Props?
Old 03-19-2008, 08:41 AM
marzo91
My Feedback: (57)
marzo91's Avatar
Default RE: TBM Props?
Don't make a comparison just by the RPM. RPM on the ground means nothing. You said yourself it pulls better than ever with the TBM. For starters, the Zinger may be a poor choice as a baseline. The whimpy Zinger flattens out to about a 4 pitch on high RPM, so it will turn alot on the ground WOT. AS you'll see, some people don't like the TBM prop, but I understand they are supposed to be the same as a Zoar, BME, NX, and several others.
On my 50cc engines, (Brison 3.2s) I use a MSC 22x8 for the best results. They also turn the least RPM over the others. They are wide, and they load the engine a bunch.
Use what pulls the plane through the sky the best.
