RCU Forums - View Single Post - VACUUM FORMING IDEAS
Old 03-20-2008 | 07:47 AM
  #52
garyshy
Default RE: VACUUM FORMING IDEAS
Cub Man, I also had that problem, there are three things that might be wrong, First, make your frame a little larger, there is not enough plastic to go around, Second, turn your pastic over before you put it on the buck. Third, if you can, heat the top of the buck a little just before you put the plastic on.I spent several several tries before I got mine correct. Hope this helps.
Gary
