RE: Question on ignition battery for RCS 180 RCS180
found my porblem:
1. MAKE SURE ALL CONNECTION ARE TIGHT AND MADE.
2. use a current meter to check that you get about a 3 mA pulse for each rotation... if not then rechech your connections. if all good. module failure.
3. Spark gap recommendation is .014inches... check you spark plug.
