RE: TJT-3000 Thrust Output
Jet FX,
I would definitely be interested in the V2 upgrade, depending on price. Let me know here or via PM what parts might be swapped out - I'm curious - as well as what you'd estimate the cost to be for the mods. Thanks again for the offer - I realize you've moved on from this turbine type...
I should probably add that I'd probably not be interested in the Kero start upgrade at this time - the turbine starts nicely with Powermax - unless it is an inexpensive option. This turbine appears to be very nicely made unit. [8D]
