RE: A Second Plane!
So there is no confusion. You can use more than 4 servos on a 4 channel radio.
5 servos is very common when using 2 wing mounted servos for ailerons hooked up via a Y harness.
I think that low wing Sonic would be a great fit and a good second plane as well.
I don't think you will be happy with the performance of the Voyager with that engine.
