ORIGINAL: docgboy
Thanks for the note Jeff. Is there some kind of modification that needs to be done to keep the servos from hitting the pipe? If you use the recomended 8611 servos is this still an issue? What happens if they do contact the pipe?
I assume you dont want to fly your Jet without elevator
Jeff a piece of fire blanket under the Servos will help?
