RE: Servo choice for a 2 x 2 Electric?
Hi Jason,
I personally don't use Hitec or Multiplex, not bagging them though. I use Futaba servos. As you can appreciate weight with an electric pattern model is important.
I currently use the 9650, 4.5 kg .11 sec @ 6v these come in at about 26 grams from memory. One on each aileron (obviously) and one on the elevator. And a normal 8-11kg servo for the rudder
I'm sure Hitec/ Multiplex have servos similar in specifications.
Hope this helps
Chris
