ORIGINAL: flycatch
I'm glad I not the only one who has had this problem. As I first stated I had little problem with programing the JR 8103. This transmitter requires a degree in higher mathmetics. Someone out there I'm sure can navigate throw the set-up. Please contact me and share your wisdom with the whole community.
If you followed the steps I listed in post #8 and you can't adjust the RAIL or LAIL for certain poistions of the flap switch, it means you have too much flap mixed in for those flap switch positions in the FLAP SYS menu. As a test set the flap mix to zero on on positions of the flap switch. You should then be able to adjust the aileron travel for any flap switch position.
PM me with what settings you want to use on the flap switch and how much travel you want on the ailerons. I'll see if I can set it up for you.
Allan
