ORIGINAL: jigeye
Yeah, this one is specifcally for a Tower .75. I photoshop'ed it and ordered one with a 2 day delivery.
You don't see any issues mounting the Pitts do you?
It should be a direct replacement without needing any modification. The only thing you'll need to do is put a hole in the cowl where the exhaust ports stick out. The only problem you may encounter is that the pitts muffler works best when mounted to an engine mounted at 90 degrees. This means that the exhaust won't come straight out the bottom.
