ORIGINAL: The Real Dogman
ok then the next Q. Is your center diff locked?? And if not, then your clutchbell should rotate! Now if your clutchbell spins then hold the clutchbell and try to spin the rears again with front wheels being locked up, then if the rear drive shaft still spins then you prolly need to take the tranny apart.
Let us know
The clutch bell dose spin like you said and the center diff should not be locked. When i hold the front tires, and the clutchbell and try to spin the rears they will not. So the rear tires will not spin with clutchbell and front wheels held. So are we back to the center diff. when i installed reverse i might not have put it together right. [&:]
Thanks for the help TRD.
