RCU Forums - View Single Post - Blade 400 Setup
Old 04-16-2008 | 09:39 PM
SeaComms's Avatar
SeaComms
Default RE: Blade 400 Setup
However, the TX will beep at you and the esc will not arm if you power on in idle up mode as the throttle has to be at 0 to arm the esc.
Just sounds like the pitch range is way off or servos may be sus; or then again maybe just was a Friday build I would definately be checking the pitch setup. If you have -10/11 at low stick, 0 at mid stick and +10/11 at full stick then the mechanics are correct and you need to adjust on the TX.
