RE: Blade 400 Setup
My servos work, im not in F mode.........I put the radio in idle up mode and when i pulled the stick down, it actually decresed the rotor speed. Do you think it could be the spindle shaft bent or something? . Something is not right at all. Also the specs say to set the rudder travel to <-90 and ->90. I have no clue what this means, you?
Thanks to all of you for the help on this pull my hair out and screm helicopter.
