RE: MVVS 26CC IFS
with a pitts, go for 16x10 to 18x8, depending on what you want to do and your plane weight
with the tuned pipe, the range will be much the same, but you will see a substantial rpm increase.
When you shorten the header and remove the end section of the tuned pipe, a 16x8 or 16x10 will scream.
