RCU Forums - View Single Post - coreless servo advantage?
Old 05-02-2003, 05:56 PM
WreckRman2
Banned
Default coreless servo advantage?
In a conventional servo, the motor has a steel core armature wrapped in wire that spins inside the magnets. In a coreless design, the armature uses a thin wire mesh that forms a cup that spins around the outside of the magnet eliminating the heavy steel core. A coreless motor does not have magnets as standard servo motors do, so they have a smoother, more constant, and stronger action. Regular servo motors have either 3 or 5 magnets (poles) which when the armature is between these, the servo motor is at its weakest.
Mulie (05-01-2020)
