Tailspin, Planelazy
Ok,
One more question. The length of these spinners are 2 1/4". The hub to the end of the crank with a prop nut for the spinner screw is about 2 1/8". Are you sure this works and are there any other things I will need to do with this. Looks like it may be real........ tight. Thanks guy's
BTW, I am going to use a 16 x 8 prop. I have an APC, but the hub is thicker than wood versions. What are you using?
Carey
