RE: building board material
Hi, I have heard about using dwsheet rock for a building board from several post and every thing about it sounds great, but I have a question about it holding pins, if you push a pin in, especially one of the larger ones and it gets bumped or other wise disturbed then the hole gets a little larger so you have got to push the pin in a little deeper. Now I,know this is nit picking and there is a lot of surface area but I like for the pin holes to kind of go away or at least shrink a little bit and not get larger every time they might get used again.
I very well could be missing something or making something out of nothing ,I have mastered both.
Thanks, Glenn.
