RCU Forums - View Single Post - wing bolt block question
Old 05-06-2008 | 09:33 PM
ChuckW's Avatar
ChuckW
Default RE: wing bolt block question
Is the block going inside the wing or on the surface? Inside it can be balsa, just harden the holes with thin CA. If it is on the surface of the wing, thin ply would probably be best. You just want to insure that the bolts won't pull through the wing.
