RE: field box
I have a Kyosho fieldbox I got from a "Scratch and Dent" sale at Tower. It was in a crushed box but some epoxy and a few brads fixed it up. Thereafter I set it on a safety stand and the vibration knocked it off and I had to once again repair it. One addition I did make was to put a block in the back corner of the drawer and drill a hole through it from the upper tray down into that block. Now I drop a 2.5mm long shanked hex driver through the tray hole and into the block in the drawer and I no longer dump the drawer (which used to be easy to do). It's also a "secret" drawer release that helps prevent "borrowing" of tools. Last club I belonged to there was a member who helped himself as needed and occasionally remembered to return the item.
