RE: Rust-Oleum?
All you Rustoleum knowledgeable folks,
I am planning on painting a new F8F Bearcat I have just finished. I will be using a color to match that of the Blue Angels. It appeared that the Rustoleum "Royal Blue" was a good match. It is glow powered with fiberglase cover over entire airplane. I did put a lot of time and work into this so I would like to know if the Rustoleum will work and look good without fuel (hot or Cold) affecting the paint. What is the consensus, should I use the Rustoleum?
Sledge_78
