RCU Forums - View Single Post - Anyone know what to do about a stripped screw?
Old 05-16-2008, 08:57 PM
maxxed101
Default RE: Anyone know what to do about a stripped screw?
If you can put any force at all on the screw with your allen wrench, then heat the screw with a pencil torch first. You should be able to remove the screw while it's still hot. If you don't have a little torch, your local crack head can hook you up.
