RCU Forums - View Single Post - Warhead Evo engine
Old 05-23-2008 | 03:28 PM
davido666's Avatar
davido666
Default RE: Warhead Evo engine
I did it by buying an ofna clutch bell shim kit, ofna flywheel nut or the raze engine sg nut, and I used non flange clutch bell bearings. You will need to use a extender in the ofna kit (part number 10099). I had to dremel a little of the cross support off on the tranny so the end of the screw on the sg shaft didn't touch the tranny support but it was a very small amount. Make sure you use the collet off the warhead engine and the flywheel of the warhead. Don't use the collet that comes with the axial engine it is to small for the spacing. you will have to rotate the carb on the axial beyond 180 degress so the needle valve does not touch the spur gear. Check my picture in my gallery.
