ORIGINAL: madmax22
no i didnt only the center.
did you check the pins though!!
I suggest you try holding the driveshaft for each diff and roll it. That will rule out if its a front or rear diff issue. If they are all rolling and spin with the shaft, then it is the center differential no doubt.
