RCU Forums - View Single Post - separate Balancer and Charger for LiPo
Old 05-29-2008 | 06:43 PM
Swift427's Avatar
Swift427
Default RE: separate Balancer and Charger for LiPo
Here's something I'm not 100% sure of maybe someone knows if the following two procedures makes any difference with respect to cycle life/performance of a LiPo.
It has been implied that you should charge through the smaller 3S 4-pin connector rather than the larger discharge connector. However, there are many (including me) that charge via the larger discharge connector because our versatile/expensive NiCd/NiMH/LiPo charger doesn't have a built-in balancer. So, we use a Blinky balancer connected to the 4-pin connector before, during and after charging to equalize the cell voltages.
Does it really make any difference whether you charge via the larger discharge connector or via the smaller 4-pin connector as long as you are balancing the cells?
Edited Addition:
I just found out another source for a 3S battery monitor - $12.95
http://www.bphobbies.com/view.asp?id...7&pid=B2632602
My LHS gets 3-5 day service from BP Hobbies. I'm going to order one. It's handy in the field and at home for checking immediate bounce back voltages after LVC as well as after resting before recharging to keep tabs on the condition of your LiPos (A,B,or C condition) through their lifespan.
