ORIGINAL: Doppelganger
Also, have you decided what you're going to do with the choke? The arm on my DL is at an odd angle. What about yours?
Steve
Yep, choke arm is at a funny angle.
I took a metal clevis and bent a 90degree " L " about 2" down from the clevis in a metal pushrod.
Drilled a hole right below the choke arm in the bottom of my cowl.
I then slipped a piece of glow fuel line over the entire length or the wire push rod.
I put the clevis pushrod assy up through the hole in the cowl under the choke arm.
The fuel tubing acts as a insulator against vibration and keeps the wire rod from ever touching the cowl.
Pull it straight down for choke on, push it back up for choke off.
Net, clean, and most of all simple.
