RCU Forums - View Single Post - newbie
Thread: newbie
Old 06-12-2008 | 07:15 PM
nubzorz's Avatar
nubzorz
Default RE: newbie
take your glowplug out and put your ignighter on it and u will see the coil glow bright red if not u need a new one and its fine the fuel is comming out of the exhaust thats no biggie it does that on break in i would suggest priming it then pulling the starter like 10 times after you prime it to move the fuel around but dont prime it to much or youll flood it in that case take the glow plug out and pull the starter fuel will come out of the hole when u do thats good also u should probly screw the low speed needle clockwise 1/16 of a turn or 1/8 and turn the high speed needle 1/8 of a turn that will lean it out a little less gas will be going to the engine have any questions fell free ill answer anything to the best of my knowledge
