RCU Forums - View Single Post - break problems
Old 06-12-2008 | 09:25 PM
Swamp3r's Avatar
Swamp3r
Default RE: break problems
Try setting your idle abit higher just to the point before the wheels start spinning with the wheels off the ground. Take the air filter off and and look in the carb you need around 1 mm gap people say but I do the wheels off the ground and adjust as high as I can without the wheels moving. Hope this helps.
