RCU Forums - View Single Post - CA versus EPOXY ?
Old 06-16-2008 | 01:09 AM
freeair
Default CA versus EPOXY ?
GUYS, what is your preferred method of fitting control surfaces [ ailerons / elevators / rudder ] do you use CA or Epoxy glues ? i have allways used epoxy myself but the new model i am doing mentions the use of CA for the hinges supplied which comes in a strip that has to be cut to sizes. also there is talk about FOAM SAFE CA which i dont have this type just the normal CA, these hinges will go into some foam as all wings are foam core . thanks.
