RCU Forums - View Single Post - servo problem??
Old 06-16-2008 | 01:42 PM
53 willys's Avatar
53 willys
Default RE: servo problem??
well I made some calls this morning and I cant find any Futaba servos locally....I am going to find some upgraded servos soon...but in the mean time I found a LHS that has some HS50 and has them instock.
can I run the HS50 with the stock esky tx??
I was searching the forums and I found that the HS55 requires some wire moding/soldering...but I cant find out if the HS50 is the same deal??
my LHS guy says it will work..but he also does not carry esky so he may not know enough about the HBK2 to even know if it works??
so if I move the stock esky digital servo from the tail to the swash and put a HS50 on the tail until I can mail order some replacement servos will that work with the stock tx??
thanks guys.
