RCU Forums - View Single Post - Lama 4 - can not trim out pivoting
Old 06-16-2008, 02:50 PM
1morecrash
Default RE: Lama 4 - can not trim out pivoting
well first thing you could do is make a hole in the canopy, righ on the windshield
so you can access the trim pots on the 4-1 with out having to remove the canopy each time.
then if it is going left turn the proportional a bit to the right. CW.
and disconect and reconect the batt. you must do this so the 4-1 can recalibrate itself.
if it after this it goes left a bit faster, then turn it the other way.
once you hit the sweet spot, it will be nice and stable.
