RCU Forums - View Single Post - P-160SX first impression and test
Old 06-18-2008 | 02:41 PM
olnico's Avatar
olnico
Default RE: P-160SX first impression and test
For those who want to setup the engine, you'll have to follow the Kerosene plug manual instructions:
http://www.jetcatusa.com/PDFFiles/Ke...anual%20V2.pdf
As well as the general instructions found on the 6.0F ECU manual:
http://www.jetcatusa.com/PDFFiles/In...al%20V6.0F.pdf
Although the engine accessory kit includes a gas tank, DO NOT USE IT and DO NOT FOLLOW THE GAS SETUP INSTRUCTIONS found on the ECU user manual. Similarily, do not get fooled by the "propane" label on the ECU plug rack. Plug the kero start line valve on this location as per the kerosene plug manual...
I am checking the new 6.0I ECU software and will post about the changes and differences that apply to the 6.0F manual soon.
