DYNAM ESC 30A
Installed a dynam 30A ESC on the Belt CP and when spooling up as the stick is moved nearly to half throttle the bird has a hard start and spins a couple of times. It is like power is put to the bird all at once before you can control it. Is their a solution to stop this and get a more softer and controled start up? Also the blades start to tilt prior to getting any power to the motor. Thanks for any suggestions.
