ORIGINAL: -SomeGuy-
Its hard to tell from the pics what your getting but there was not much difference between the 21, 25 and 25ss. SS just means it was a kit that had to be put together and since it has no engine or pipe then the only way left of knowing what model it is is by opening up the diffs. If it has the 4 spider gears and the cam style servo saver steering then its a 25 or 25ss. If it came with the ribbed pipe then that would have pointed to an ss also.
s25 came with a 2 gear diff and a cheap servo saver that did more harm than good it's an .21 savage the way you can tell is from the orange shocks, the s25 and ss came with black shocks
