RCU Forums - View Single Post - Did I stall???
Old 06-21-2008 | 04:50 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: Did I stall???
Well the 'high alpha' flight was me just trying to figure out what happens to my plane in different situations; I don't normally fly that way, nor was I flying that way when I had whatever happened happen to me. I was turning into final with the nose maybe 5 degrees down when it happened. I just brought that up because I was trying to learn stall characteristics, so I was trying to get into a stall situation, and was trying to explain that I didn't think I was that close to a stall. When I did that, the wings wanted tip, and the plane wanted to sink. I kept it up as long as I could with low power, then pulled out with some throttle.
I have PPM (FM) receiver. 2300mah battery, and Voltwatch showing second to highest green bulb. Is PPM better for this kind of stuff? Is it worth spending $100 on a new receiver?
