RCU Forums - View Single Post - Jet Cat p-80 spool up time
Old 06-21-2008 | 08:42 PM
acw
Default RE: Jet Cat p-80 spool up time
In my opinion, you would be better of buying a 120SE and limit the RPM if needed. The weight is almost the same and the size is the same as the P80. The lag is a lot less with the SE version and the extra thrust will let you use it in many more jets.
Arnaud
