ORIGINAL: EARRNHARDT3
Well i took apart the rear diff and it has just the 2 spider gears. So if i read every thing above right i have a Savage 21.
I do have one question can i put the Savage X SS diffs in the 21's bulk heads ( housing that hold the diff/ring gear in to the pinion gear ) Or do i need the X SS 's housings also?
Thanks for the helps Guys
E3
You can put the differentials, ring and pinion in the old housings, just did two of them. BB
