Old 05-12-2003, 11:17 PM
jtholley03
Default Got halfway
And that was switch (not stitch).
Go to menu 1, servos, travel/curve. Flap servos, you have already set the flap input. Go to input 2, elevator, select the value field, pull back on the elevator and choose a value for ele->flap mix, push down ele and set that mix, do same for the other flap servo. ........
OK how do I "set that mix".
Only way I could figure to do it was with the + or - not the stick.
What this did was apply flap anytime I applied elevator.
Backward from what I wanted. Starting simple I just want to compensate elevator when I apply flap. And then work in throttle.
What I have learned would be good to throw into expo for exteme elevator to 3D.
Got everything else prograamed but totally cornfused now.
Thx, I have learned more todau than I have in 3 yrs (yes very sad I know).
