RCU Forums - View Single Post - Draining fuel and running the engine until it quits
Old 07-03-2008 | 02:43 PM
  #40
HighPlains
Default RE: Draining fuel and running the engine until it quits
But likely not totally empty.
You are right. It is filled with air. But not a drop of useable fuel.
For those of you running the engine dry on the ground, do it then wait for a minute. Then hook up the glow plug and spin the engine again. Quite often they will fire again with the fuel that is still in the engine.
