RCU Forums - View Single Post - hype 3d
Thread: hype 3d
Old 05-14-2003 | 05:54 PM
DominicM's Avatar
DominicM
Default hype 3d
don't want to patronise you but make sure you've re-inforced the horiz stab. The thickness of the sides of the fuse aren't thick enough to deal with the forces. If you're going to box the battery in the tail, then put some tri-balsa inside the tail up against the horiz stab and inside fuse sides. IT'S A MUST BEFORE YOU EVEN FLICK THE ENGINE !
