RE: SLASHES GONE WILD!
It looks actaully right on with the 2.5 revo chassis. And if they made it with the 3.3 chassis it probably wouldnt jump correctly. It has to do with the smaller tries used on the slayer compared to the larger on the revo's. With less rotating mass you get less pull in the front end. I know with my revo exerience if your not on throttle with lower speeds the revo will nose dive with the longer 3.3 chassis. The bigger tires help stablize the front end with a longer chassis.
The slayer would need a bigger body anyways to fit the 3.3 chassis and I am sure it would be hard to keep the nose up.
