Problems with blade cp: HELP!!
Hey, ive had numerous problems with the blade cp pro, and although they are fairly small, it would at least be helpful to know the cause of
them so here goes...
-In the middle of flight, the blade cp jolts for a split second as if the motor cut out, or the throttle reversed on me, then goes back to regular flight
-When i land for a short break and keep the motor running (by "break" i mean just to adjust the trim on the transmitter) both the tail and main motors die on me, and the servos continue to work. The red light goes on, and to fly again i have to unplug the battery then plug it back in. I also felt it once at this point, and realized it was really hot (is this normal?) Oh one more thing to add here, this happens
when I land on grass, so the tail motor usually gets stopped by the grass, which may lead to a burnout or something. Maybe the motors just shut off because of that, I really don't know.
-Sometimes when i fly, mostly near the beginning of the battery life, the servos jerk to the right suddenly, then jerk again, so i constantly have to push the control stick to the left (this is not because i am setting the trim to far to the right, it just jerks randomly, then goes back to an even balance)
Im hoping that all these problems are all being caused by one faulty part (im thinking it could be the 3 in 1, because all three of the problems are control problems.
