RCU Forums - View Single Post - Velocity Stack on the 35 gasser ??
Old 07-15-2008 | 07:48 AM
pe reivers
Default RE: Velocity Stack on the 35 gasser ??
That is not a velocity stack, but the carb mounting base.
Your dead sticks are probably due to lean mixtures. The engine should four stroke slightly up to half throttle. Above that, tune for clean running.
Set idle speed at 1600 - 1800
