RCU Forums - View Single Post - Solved my problem, with airboat tilt insted of slide
Old 07-16-2008, 03:28 PM
sportygreg
sportygreg's Avatar
Default RE: Solved my problem, with airboat tilt insted of slide
I had the same problem when I coated a hull with resin that didn't have enough hardener.Put it in the sun or use a hair dryer-the heat will help greatly.[8D]
