RCU Forums - View Single Post - Perry Pump ???
Thread: Perry Pump ???
Old 03-19-2002 | 07:00 AM
Aerosplat
My Feedback: (12)
Default Perry Pump and OS 7d
Originally posted by GalenB
I have a ST 3000 for my H9 CAP 232 and am considering upgrading the carb to a 7D and getting the perry pump. Can you provide some detail about how the crankcase is tapped for pressure and how the pump is installed?
GalenB,
Before you purchase that OS 7D carb, I suggest you call Perry Pumps (630-858-3160) and ask them about the best pump / carb setup for your engine. They are very helpful nad knowledgeable. I'm betting you can purchase their pump and pump carb for about the same $'s as the OS 7D will cost you.
I put their pump and carb on my ST 2300 and have had great results with it.
The pump is supplied with a pressure fitting that is installed into the crankcase by drilling and tapping a 6/32 hole (usually in the center of the engine back plate). The pump instructions explain how to do it.
