ORIGINAL: slayerphonics
ORIGINAL: Jamie22
I had more problems with the tray stiffner. Take and cut you a piece of fuel line bout an 1/8th inch thick. Put in between the chassis and tray on the rear bolt of the tray. Then put the rubber rings under each bolt of the servo. Done all of that to mine and havent had another servo mess up
Thats alot of useless work and not the correct fix,
1. Align your carb to the stroke of the servo arm.
2. Set your EPA so that at WOT you can pull the throttle open by hand another 2mm
3. Buy a quality servo
We race alot of 8ights at our track, nobody uses the o-rings or tray stiffner to fix the throttle servo, its all about alignment, EPA and quality servos.
The tray stiffner looks cool though,
