Well I finally started this. It will be long project. Theres two areas which will be the most difficult, 1) the front end, 2) placement of transmission.
Im planning on use a Axial or High Lift rear axle.
First I started the chassis. Using the one provided in the kit proceeded to adapt it to an aluminum one and make it look as flawlessly as possible.
Mock up with tires. Im thinking on keeping those in the back. For th front I still dont know if use the ones from the kit. Skinny tires in that scale are hard to find specially with a 12mm hex.
Also thinking of going with moon caps!
The electric engine will be concealed inside the model's engine. The two halves are joined by screws to make it easier in case of any problems with electric unit.
