RCU Forums - View Single Post - Timing of 58CD
Old 07-23-2008 | 12:14 AM
mboland's Avatar
mboland
Default RE: Timing of 58CD
Simply turn the crank until the conrod is at the very top ie, the piston is at it's highest, most extended position.
While holding the crank in that position, and with the barrel in the position of the port showing in both carb and exhaust, held in place with your toothpick in each, slide the piston in.
Bolt up.
Done.
