RCU Forums - View Single Post - Dx6i Binding and ESC setup/programming
Old 07-24-2008 | 07:33 PM
Tom Z
Default RE: Dx6i Binding and ESC setup/programming
No problem!
Here is one setting you can make that will be the same.
Throttle hold -0.5%. (make sure it is minus 0.5 percent).
If you need a specific setting (s) you can see what I have. Let me know.
I used all the defaults and went from there.
Throttle and pitch settings were Finless settings to start then were modified by a guy in my flying club
to tame the heli down to learn with. Like 75% throttle max, and a mild pitch curve. Used for hover and gentle flying only.
Also added D/R or Expo which really helped out.
I used the Finless gyro setup video and a setup guide on this site then took it from there.
Tom
