RCU Forums - View Single Post - "air-buggy" - stage one
Old 07-25-2008, 10:18 PM
alaskadf300
alaskadf300's Avatar
Default RE: "air-buggy" - stage one
Thanks!, I have put about 20 hrs total into it at this point, including thought about design stuff. It actually handles rather well since I extended the rear wheels outward from stock, it just gracefully turns at low to medium speeds, but if you go fast and make a sudden turn, it will slide a 180 right around with no leaning or tipping. If I had used larger rear tires, it would probably try to flip, but I also have them cambered so only the inner edges are contacting the ground.
