RCFoolish:
use top right triple rate switch as my idle down (center) and kill (down),
idle down per man.P.33 kill = THR-CUT per man.P.34 (Both function off Chan 3) Ryobi would not die with butterfly closed; sodered small hole in butterfly closed, awaiting test stand run.
upper left switch as fiber optic kill. And using left hand side slide as choke (up-off, down-on).
I do not visualize/ understand how signal is sent to the FO kill unit? Does it take a dedicated chan on RX?
I visualize the choke on a dedicated chan. with its own servo. Correct?
Is it correct that you are using 3 Rx chans in your set-up for enginge management? 2 for fuel and 1 for elec. ignition
Rx 148DF (8 Chan) Presently got all assigned except Chan 5 Plane US 120 Quad
