ORIGINAL: Safety Hawk
ORIGINAL: Furadi
It just seems like I almost need a shoe horn to get the cap on.....most of it is occupied by servo wires jammed under the switch and around the receiver. Maybe the receiver area is fine, but the area under the switch could be bigger.
That makes sense, I don't use the switch.
Funny you should say that.....on sunday, my switch started acting up during the qualifiers, so I pulled it out before the main and just ran a servo extension from the receiver to the battery box. So right now I'm not running a switch either. But I miss the convenience of having it.
Thats the exact reason I don't use a switch
I just run the battery lead outside of the box and the servo extension outside of the receiver box. It's as easy as using a switch IMO.
